Ana içeriğe geç
How to clean and reapply thermal paste on ATI Radeon X1900 XTX
Neye ihtiyacın var
  1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 1, 2 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 1, 2 resimden 2.
    • Start by removing the card from the PC if you haven't already.
  2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 2, 3 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 2, 3 resimden 2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 2, 3 resimden 3.
    • The fan's power cable is located towards the bottom-left of the card.
    • Disconnect the cable from the card.
    • The cable and its connector on the X1900 are fragile. Be careful, and try not to use excessive force when removing it.
  3. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 3, 3 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 3, 3 resimden 2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 3, 3 resimden 3.
    • Removing the heatsink from the card:
    • The clamp is held on by four small Phillips screws. Remove them, then the clamp.
    • Remove the four phillips screws surrounding the clamp.
  4. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 4, 1 resimden 1.
    • Separate the heatsink and the card.
    if you're doing this on a Mac, you have to take out the two small screws on the dvi connection end and loosen the dvi connection nuts so the heatsink will separate.
    Matt Kennedy - Yanıt
  5. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 5, 2 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 5, 2 resimden 2.
    • Replacing Thermal Paste:
    • Using a Q-tip/cotton swab and rubbing alcohol, clean the copper plate that protrudes from the bottom of the heatsink.
  6. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 6, 2 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 6, 2 resimden 2.
    • Removing the heatsink's plastic cover:
    • Remove these Phillips screws.
    • Seperate the plastic cover from the metal heat sink.
  7. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 7, 2 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 7, 2 resimden 2.
    • Cleaning dust out of the heat sink:
    • Using a cotton swab/q-tip, clean the edges of the heat sink. You can also use canned air if available.
  8. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 8, 2 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 8, 2 resimden 2.
    • Using the same method that you used to clean the copper plate, clean the surface of the GPU die.
  9. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 9, 3 resimden 1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 9, 3 resimden 2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: adım 9, 3 resimden 3.
    • Re-Applying Thermal Paste:
    • Apply a small glob of thermal paste to the corner of the die, (I recommend using Arctic Silver 5) and use an index card to spread a thin, even layer of it over the surface of the chip.
    • For more detailed directions, follow our Applying Thermal Paste Guide.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Chris Green
36.978 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.519 adet Kılavuz yazıldı
Bir Yorum
Super!!!!! j'ai suivi a la lettre; j'espère sauver ma carte; j'attends la pate thermique.
guz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 13,270
