Ana içeriğe geç
Giriş
If you have print quality problems, clean the corona wire.
  1. How to clean the Brother HL-5240 corona wire, Drum Unit and Toner Cartridge: adım 1, 1 resimden 1.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. How to clean the Brother HL-5240 corona wire: adım 2, 3 resimden 1. How to clean the Brother HL-5240 corona wire: adım 2, 3 resimden 2. How to clean the Brother HL-5240 corona wire: adım 2, 3 resimden 3.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: adım 3, 3 resimden 1. How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: adım 3, 3 resimden 2. How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: adım 3, 3 resimden 3.
    • Clean the corona wire inside the drum unit by gently sliding the blue tab all the way to left and then back to the far right. Repeat several times.
    • Make sure the arrow on the tab lines up with the arrow on the drum unit before you place it back into the printer. If the tab is in the wrong place, a vertical line might appear on future print jobs.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Ruiz
165 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G14
5 Üyeler
5 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 12,626
