Ana içeriğe geç
How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45
Neye ihtiyacın var
  1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Battery: adım 1, 2 resimden 1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Battery: adım 1, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry the back panel off.
  3. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 3, 2 resimden 1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 3, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 4, 2 resimden 1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the ribbon cable with a pair of tweezers.
  5. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 5, 1 resimden 1.
    • Lift and remove the battery.
  6. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Fan: adım 6, 1 resimden 1.
    • Gently peel off the tape from the fan.
  7. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 7, 2 resimden 1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 7, 2 resimden 2.
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 8, 1 resimden 1.
    Satın Al
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 9, 2 resimden 1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 9, 2 resimden 2.
    • Grab the sides of the fan assembly and remove it by lifting upwards.
  10. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 10, 1 resimden 1.
    • Remove the tape connected to the fan covering plate.
  11. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 11, 1 resimden 1.
    • Gently pull the covering plate from the covering tab.
  12. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 12, 1 resimden 1.
    • Remove the covering plate.
  13. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 13, 2 resimden 1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: adım 13, 2 resimden 2.
    • From the back, push the fan out of the motor.
    • Clean the fan using a damp cloth, and allow to dry.
Sonuç
Bryann Tan
877 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,368
