Ana içeriğe geç
How to clean the Pentax PZ-10 gears
Neye ihtiyacın var
  1. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: adım 1, 2 resimden 1. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: adım 1, 2 resimden 2.
    • Place the lens face up to locate the bottom cover.
    • Remove the two 7mm screws using a J0 screwdriver.
    • Remove the six 4.3 mm screws using a J0 screwdriver.
  2. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover: adım 2, 1 resimden 1.
    • After the screws are removed, the bottom cover should easily pry off.
  3. How to clean the Pentax PZ-10 gears, Accessing Gears: adım 3, 2 resimden 1. How to clean the Pentax PZ-10 gears, Accessing Gears: adım 3, 2 resimden 2.
    • Using a J0 screwdriver, remove the 4mm screw holding the metal plate to expose the gears.
  4. How to clean the Pentax PZ-10 gears, Removing Gear Housing Plate: adım 4, 1 resimden 1.
    • Using a pair of tweezers, gently remove the metal plate covering the gears.
    • Part of the plate's tab fits into a socket. Try to pivot around it when removing the plate to prevent bending the plate.
    • Be careful with the gears because some may be loose.
  5. How to clean the Pentax PZ-10 gears, Cleaning the Gears: adım 5, 2 resimden 1. How to clean the Pentax PZ-10 gears, Cleaning the Gears: adım 5, 2 resimden 2.
    • Use tweezers to rotate gears or remove any large particles obstructing their rotation.
    • Smaller particles can be cleared using a microfiber cloth only. Other fabrics may leave residual fibers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryan Sugiarto
252 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 864
