Ana içeriğe geç
How to clean the Samsung SGH-E317 keypad
Neye ihtiyacın var
  1. How to clean the Samsung SGH-E317 keypad, Battery: adım 1, 1 resimden 1.
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: adım 2, 1 resimden 1.
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: adım 3, 1 resimden 1.
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: adım 4, 1 resimden 1.
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: adım 5, 1 resimden 1.
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: adım 6, 1 resimden 1.
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: adım 7, 2 resimden 1. How to clean the Samsung SGH-E317 keypad: adım 7, 2 resimden 2.
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: adım 8, 2 resimden 1. How to clean the Samsung SGH-E317 keypad: adım 8, 2 resimden 2.
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: adım 9, 2 resimden 1. How to clean the Samsung SGH-E317 keypad: adım 9, 2 resimden 2.
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: adım 10, 1 resimden 1.
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: adım 11, 1 resimden 1.
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: adım 12, 2 resimden 1. How to clean the Samsung SGH-E317 keypad: adım 12, 2 resimden 2.
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joe Cavaletto
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G23
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 947
