Ana içeriğe geç
How to clean the Sega Genesis game port
Neye ihtiyacın var
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: adım 1, 1 resimden 1.
    • Fold fine grit sand paper over a credit card.
    FixBot'a Sor
  2. How to clean the Sega Genesis game port: adım 2, 1 resimden 1.
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
    FixBot'a Sor
  3. How to clean the Sega Genesis game port: adım 3, 1 resimden 1.
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
    FixBot'a Sor
  4. How to clean the Sega Genesis game port: adım 4, 1 resimden 1.
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
    FixBot'a Sor
Bitiş Çizgisi
12 farklı kişi bu kılavuzu tamamladı.
Erik Bjornstrom
852 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G29
4 Üyeler
17 adet Kılavuz yazıldı
5Kılavuz Yorumları
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Yanıt Paylaş
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Yanıt Paylaş
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Yanıt Paylaş
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - Yanıt Paylaş
I tried alcohol and toothbrush, q-tips, and looked over the board for circuit problems. I was still getting a black screen for every game i tried. But this worked perfectly. I'm shocked. My contacts were already shiny clean but they needed light sandpaper apparently.
colinplank - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 36
Son 30 gün: 174
Her zaman: 39,384
