Ana içeriğe geç
How to clean the Shure SM58 Grille
Neye ihtiyacın var
  1. How to clean the Shure SM58 Grille, Grille: adım 1, 1 resimden 1.
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. How to clean the Shure SM58 Grille: adım 2, 2 resimden 1. How to clean the Shure SM58 Grille: adım 2, 2 resimden 2.
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
  3. How to clean the Shure SM58 Grille, How to clean the Shure SM58 Grille: adım 3, 1 resimden 1.
    • Put two drops of dish soap into a cup.
    • Add water to cup until half full.
  4. How to clean the Shure SM58 Grille: adım 4, 1 resimden 1.
    • Place the grille in the solution of soap and water.
    • Let the grille soak for half an hour.
  5. How to clean the Shure SM58 Grille: adım 5, 1 resimden 1.
    • Remove the grille from the cup and rinse it with cold water.
    • Allow the grille to air dry.
    • Make sure the grille and the foam inside it are completely dry before placing it back on the microphone.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
nat coll
733 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 12,563
