Giriş
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. This is the air filter assembly
    • This is the air filter assembly
  5. Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  6. Thoroughly clean or replace the air filter.  This can be done with compressed air or by rinsing it with water.
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  7. Reassemble the air filter assembly and slide the particle bin back into place
    • Reassemble the air filter assembly and slide the particle bin back into place
Sonuç
3 başka kişi bu kılavuzu tamamladı.
Scott Leonard
439 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G6
2 Üyeler
Bir Yorum
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 7
Son 30 Gün: 10
Her zaman: 4,701
