Ana içeriğe geç
How to clean/replace buttons on the Skytex SP728
Neye ihtiyacın var
  1. How to clean/replace buttons on the Skytex SP728, Case: adım 1, 1 resimden 1.
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: adım 2, 1 resimden 1.
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: adım 3, 1 resimden 1.
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: adım 4, 1 resimden 1.
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: adım 5, 1 resimden 1.
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: adım 6, 1 resimden 1.
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Nelson
219 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G1
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 189
