Ana içeriğe geç
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: adım 1, 2 resimden 1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: adım 1, 2 resimden 2.
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: adım 2, 2 resimden 1. How to clear Lexmark Intuition S505 paper jam: adım 2, 2 resimden 2.
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: adım 3, 1 resimden 1.
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: adım 4, 1 resimden 1.
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
Sonuç
Once the paper obstruction is removed, your printer should print smoothly without any problems.
2 farklı kişi bu kılavuzu tamamladı.
Omar
132 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G38
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,822
