Ana içeriğe geç
How to create a Tails Live USB
Neye ihtiyacın var
  1. How to create a Tails Live USB, Download Tails OS: adım 1, 2 resimden 1. How to create a Tails Live USB, Download Tails OS: adım 1, 2 resimden 2.
  2. How to create a Tails Live USB, Download and install BalenaEtcher: adım 2, 1 resimden 1.
    • Insert the USB flash drive into an available USB port on your computer and launch Etcher.
    • In Etcher, click "Flash from file" and select the Tails ISO image you downloaded earlier.
    • Select the USB flash drive as the target device.
    • Double-check to ensure you have selected the correct drive, as the process will erase all data on the selected drive.
    • Click "Flash!" to start the process. Etcher will copy the Tails OS to the USB drive.
    • Once the flashing process is complete, safely eject the USB drive from your computer.
    • Etcher should do this automatically, however it is still good practice to check that the drive was ejected properly.
    • Insert the Tails live USB into the computer you want to use.
    • Restart the computer and enter the boot menu by pressing the appropriate key during startup (usually F2, F12, or Delete).
    • Select the USB drive as the boot device from the boot menu.
    • Tails will start, and you'll be presented with the Tails Greeter screen.
    • Follow the on-screen instructions to configure language, keyboard, and other settings.
    • Once completed you will be able to use your computer in a secure and private live environment. Your online activities are routed through the Tor network for anonymity.
Sonuç
Creating a Tails live USB using this iFixit guide provides you with a secure and private way to use Tails OS on any computer without leaving traces. Remember to always use Tails responsibly and respect the privacy and security it offers.
7 farklı kişi bu kılavuzu tamamladı.
Jacob Mehnert
44.284 İtibar
51 adet Kılavuz yazıldı
Ekip
iFanatics iFanatics üyesi
Community
63 Üyeler
218 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 286
Son 30 gün: 1,322
Her zaman: 19,157
