Ana içeriğe geç
How to create a macOS Time Machine backup
    1. How to create a macOS Time Machine backup, How to create a macOS Time Machine backup: adım 1, 2 resimden 1. How to create a macOS Time Machine backup, How to create a macOS Time Machine backup: adım 1, 2 resimden 2.
      • Open the Time Machine preferences menu, located toward the bottom of your System Preferences pane.
      FixBot'a Sor
      Yorum Ekle
    2. How to create a macOS Time Machine backup: adım 2, 2 resimden 1. How to create a macOS Time Machine backup: adım 2, 2 resimden 2.
      • Before you select a backup disk, use the Options menu to exclude any folders you don't want in your backup.
      • Use the + and – buttons to add or remove folders from the exclusion list.
      • The Options menu is also home to a couple other settings:
      • If your machine is a laptop, you can check the first box to allow the computer to back up while it is using battery power (not plugged in).
      • Check the second box if you want a notification whenever Time Machine automatically deletes a backup to save space.
      FixBot'a Sor
      Yorum Ekle
    3. How to create a macOS Time Machine backup: adım 3, 2 resimden 1. How to create a macOS Time Machine backup: adım 3, 2 resimden 2.
      • If your external drive isn't already connected to your computer, connect it now.
      • Click the Select Backup Disk button and select your external drive.
      • The selector should list any storage drives connected to your computer. If you don't see the drive you want, make sure it shows up in Finder, and try disconnecting and reconnecting it.
      • Unless the storage drive you selected is already being used as a Time Machine backup, Time Machine will erase everything on it before creating the first backup.
      FixBot'a Sor
      Yorum Ekle
    4. How to create a macOS Time Machine backup: adım 4, 1 resimden 1.
      • If you want Time Machine to automatically make future backups, check the box on the left side of the settings pane labeled Back Up Automatically.
      • If your backup drive is already configured for Time Machine, this box may be checked automatically after you select the disk.
      • If you select Back Up Automatically, Time Machine will make backups once an hour, and keep backups as follows:
      • Hourly for 24 hours
      • Daily for the past month
      • Weekly for all previous months
      FixBot'a Sor
      Yorum Ekle
    5. How to create a macOS Time Machine backup: adım 5, 2 resimden 1. How to create a macOS Time Machine backup: adım 5, 2 resimden 2.
      • To manually start a backup, first check the box labeled Show Time Machine in menu bar.
      • Then click the new Time Machine icon in the menu bar, and select Back Up Now.
      FixBot'a Sor
      Yorum Ekle
    6. How to create a macOS Time Machine backup: adım 6, 3 resimden 1. How to create a macOS Time Machine backup: adım 6, 3 resimden 2. How to create a macOS Time Machine backup: adım 6, 3 resimden 3.
      • Before the backup begins, Time Machine will configure the drive you have selected (if necessary), and prepare the files on your main drive to be backed up.
      • You can monitor the backup's progress in the Time Machine preferences pane of System Preferences.
      • You may continue using your Mac while the backup is running. The backup will continue even if you close the Time Machine preferences window.
      • The first backup could take a significant amount of time, depending on how much of your data you chose to exclude and the speed of your backup drive. Subsequent backups will be shorter.
      • When the backup is finished, a Backup Complete notification will appear on the upper-right side of the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Once your backup is finished, you’re done! Rest easy and know that you’ve got some protection, should you ever need it.
45 farklı kişi bu kılavuzu tamamladı.
Taylor Dixon
72.704 İtibar
94 adet Kılavuz yazıldı
6Kılavuz Yorumları
Hi, will the Time Machine also backup the MacOS?
Alex Yap - Yanıt Paylaş
Bonjour, j’ai un disque dur occupé à hauteur de 247Go et la sauvegarde Time Machine s’est arrêtée à 40Go environ sans qu’il y ait de notifications dans le coin droit comme indiqué…
J’ai l’impression qu’il en manque donc comment être sûr que cela a bien fonctionné ?
Victor Cabrera - Yanıt Paylaş
TimeMachine will not backup the OS. You restore a TimeMachine backup to a drive AFTER installing a MacOS on the new drive. If you want to Restore an OLDER … (non-current) version of MacOS (like Mojave) you need to create a make a MacOS USB Installer ThumbDrive while the OS is still current.
Jason Ball - Yanıt Paylaş
How do you clone a failing Time Machine back up? This is a timely question.
Chris Leeds - Yanıt Paylaş
How do you create and make a MacOS USB installer Thumbdrive Jason
Gill - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 59
Son 30 gün: 277
Her zaman: 56,973
