Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Open the Time Machine preferences menu, located toward the bottom of your System Preferences pane.
Before you select a backup disk, use the Options menu to exclude any folders you don't want in your backup.
Use the + and – buttons to add or remove folders from the exclusion list.
If your machine is a laptop, you can check the first box to allow the computer to back up while it is using battery power (not plugged in).
Check the second box if you want a notification whenever Time Machine automatically deletes a backup to save space.
If your external drive isn't already connected to your computer, connect it now.
Click the Select Backup Disk button and select your external drive.
If you want Time Machine to automatically make future backups, check the box on the left side of the settings pane labeled Back Up Automatically.
If you select Back Up Automatically, Time Machine will make backups once an hour, and keep backups as follows:
Hourly for 24 hours
Daily for the past month
Weekly for all previous months
To manually start a backup, first check the box labeled Show Time Machine in menu bar.
Then click the new Time Machine icon in the menu bar, and select Back Up Now.
Before the backup begins, Time Machine will configure the drive you have selected (if necessary), and prepare the files on your main drive to be backed up.
You may continue using your Mac while the backup is running. The backup will continue even if you close the Time Machine preferences window.
The first backup could take a significant amount of time, depending on how much of your data you chose to exclude and the speed of your backup drive. Subsequent backups will be shorter.
When the backup is finished, a Backup Complete notification will appear on the upper-right side of the screen.
41 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Bonjour, j’ai un disque dur occupé à hauteur de 247Go et la sauvegarde Time Machine s’est arrêtée à 40Go environ sans qu’il y ait de notifications dans le coin droit comme indiqué…
J’ai l’impression qu’il en manque donc comment être sûr que cela a bien fonctionné ?
TimeMachine will not backup the OS. You restore a TimeMachine backup to a drive AFTER installing a MacOS on the new drive. If you want to Restore an OLDER … (non-current) version of MacOS (like Mojave) you need to create a make a MacOS USB Installer ThumbDrive while the OS is still current.
How do you clone a failing Time Machine back up? This is a timely question.
