Ana içeriğe geç
How to diagnose Samsung Galaxy A40 Charging Problems
Videoya Genel Bakış
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: adım 1, 3 resimden 1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: adım 1, 3 resimden 2. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: adım 1, 3 resimden 3.
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: adım 2, 3 resimden 1. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: adım 2, 3 resimden 2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: adım 2, 3 resimden 3.
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: adım 3, 3 resimden 1. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: adım 3, 3 resimden 2. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: adım 3, 3 resimden 3.
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: adım 4, 3 resimden 1. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: adım 4, 3 resimden 2. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: adım 4, 3 resimden 3.
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: adım 5, 3 resimden 1. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: adım 5, 3 resimden 2. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: adım 5, 3 resimden 3.
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: adım 6, 3 resimden 1. How to diagnose Samsung Galaxy A40 Charging Problems: adım 6, 3 resimden 2. How to diagnose Samsung Galaxy A40 Charging Problems: adım 6, 3 resimden 3.
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
ZFix
191.470 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.485 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 46
Son 30 gün: 178
Her zaman: 8,110
