Ana içeriğe geç
How to perform a Hard Reset on the Nintendo DS Lite
Neye ihtiyacın var
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: adım 1, 1 resimden 1.
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: adım 2, 2 resimden 1. How to perform a Hard Reset on the Nintendo DS Lite: adım 2, 2 resimden 2.
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: adım 3, 2 resimden 1. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: adım 3, 2 resimden 2.
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: adım 4, 3 resimden 1. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: adım 4, 3 resimden 2. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: adım 4, 3 resimden 3.
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: adım 5, 1 resimden 1.
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: adım 6, 3 resimden 1. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: adım 6, 3 resimden 2. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: adım 6, 3 resimden 3.
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: adım 7, 2 resimden 1. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: adım 7, 2 resimden 2.
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: adım 8, 1 resimden 1.
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Artem Ivat
2.709 İtibar
12 adet Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
156 Üyeler
292 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 83
Son 30 gün: 365
Her zaman: 9,339
