Ana içeriğe geç
How to downgrade Jadoo2
Neye ihtiyacın var
  1. How to downgrade Jadoo2, Turn off Jadoo2: adım 1, 2 resimden 1. How to downgrade Jadoo2, Turn off Jadoo2: adım 1, 2 resimden 2.
    • Press the Power switch on the back of the Jadoo2, or press the power button on the remote to turn it off.
  2. How to downgrade Jadoo2, Starting the process: adım 2, 1 resimden 1.
    • To begin, press the power button on your remote, or press the switch on the back to turn on the Jadoo2
    • While turning the Jadoo2 on, Press & Hold the OK button on your remote for 10 seconds.
    • You should see a Menu with some options such as doing a Factory reset and many more.
    • On the menu you should see an option that says “Run the previous software”
    • Click the corresponding button for “Run the previous software”
    • Once it is done booting up. Everything should be like the old software.
Sonuç
Unless the software asks if you want to update the software, there is no return.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 15
