Ana içeriğe geç
How to easily fix a Xbox 360 drive that wont open.
Neye ihtiyacın var
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: adım 1, 2 resimden 1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: adım 1, 2 resimden 2.
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: adım 2, 1 resimden 1.
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: adım 3, 2 resimden 1. How to easily fix a Xbox 360 drive that wont open.: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: adım 4, 2 resimden 1. How to easily fix a Xbox 360 drive that wont open.: adım 4, 2 resimden 2.
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: adım 5, 1 resimden 1.
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: adım 6, 2 resimden 1. How to easily fix a Xbox 360 drive that wont open.: adım 6, 2 resimden 2.
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
Sonuç
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15 farklı kişi bu kılavuzu tamamladı.
Matt Weatherly
1.332 İtibar
2 adet Kılavuz yazıldı
8 Yorum
the picture of the exbox is not mine
dongwillows - Yanıt
the picture you show is not my console
dongwillows - Yanıt
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - Yanıt
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - Yanıt
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 35
Son 30 gün: 210
Her zaman: 11,490
