Ana içeriğe geç
How to extract a leaked battery from a pocket-torchlight
Neye ihtiyacın var
  1. How to extract a  leaked battery from a pocket-torchlight, battery: adım 1, 2 resimden 1. How to extract a  leaked battery from a pocket-torchlight, battery: adım 1, 2 resimden 2.
    • To successfully extract a cylindrical dry-cell (e.g. AAA , baby–cell) on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill. Drill it through the bottom of the battery to get a grip on it and retract it. Works ! Do not destroy the case by using excessive force.
Sonuç
To successfully extract a cylindrical dry-cell on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill.
Drill it through the bottom of the battery to get a grip on it and retract it. Works like a charm!
Counter the drill at the battery-case but NOT against the torch'es topside to avoid structural damage to the torchlight.
2 farklı kişi bu kılavuzu tamamladı.
ein Stein
204 İtibar
1 Kılavuz yazıldı
7 Yorum
works like a charm! there is no better way. obviously, the leaked battery is being destroyed in the process.
ein Stein - Yanıt
works for aluminium € 30 “creed-light”
ein Stein - Yanıt
getting the battery out is much easier than publishing a guide here. wow they make it complicated!
ein Stein - Yanıt
don’t forget to scratch off any insulating rust caused by the electrolyte on the battery–contacts of the torchlight.
ein Stein - Yanıt
fragile plastic torches may not withstand the force required to drill, breaking the torch.
unless you have a strong magnet to pull the battery, it is unfortunate.
ein Stein - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 810
