Giriş
This guide will show how to fix squeaky parts on the wheelchair.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
  1. Locate the source of the squeaking. Typically, this will be one of the rear wheels, castor wheels, or brakes. Clean and remove any dirt or rust from the source of the squeaking.
    • Locate the source of the squeaking.
    • Typically, this will be one of the rear wheels, castor wheels, or brakes.
    • Clean and remove any dirt or rust from the source of the squeaking.
    • You may need to partially disassemble the squeaky part in order to thoroughly clean it.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Check for improper assembly.
    • Check for improper assembly.
    • Refer to the teardown to check that the wheelchair is properly assembled.
    • Check for proper lubrication. If not lubricated, lubricate thoroughly with bike grease.
  4. Roll the wheelchair around to check if the squeaking has stopped.
    • Roll the wheelchair around to check if the squeaking has stopped.
    • If the squeaking still continues, recheck the chair until the problem is fixed.
Sonuç
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
Bir başkası bu kılavuzu tamamladı.
Kali Slaughter
207 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G8
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
sandraphleb - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 29
Her zaman: 1,757
