Ana içeriğe geç
How to fix Leaks in Shower Tiles by Caulking
Neye ihtiyacın var
  1. How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: adım 1, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: adım 1, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: adım 1, 3 resimden 3.
    • Using a putty knife, remove the old caulk from the surface.
    • While using the scraper, hold the sharp end away from you.
  2. How to fix Leaks in Shower Tiles by Caulking: adım 2, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 2, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 2, 3 resimden 3.
    • Using a damp cloth, wipe the surface to remove the scraped caulking.
    • Using another cloth, wipe the surface with disinfectant.
  3. How to fix Leaks in Shower Tiles by Caulking: adım 3, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 3, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 3, 3 resimden 3.
    • Place the caulking tube in the caulking gun.
    • Place the back of the tube into the gun.
    • Push the front of the tube inside.
    • Twist the hook at the end of the caulking gun inwards to hold the caulking tube in place.
  4. How to fix Leaks in Shower Tiles by Caulking: adım 4, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 4, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 4, 3 resimden 3.
    • Cut the tip of the caulking tube at an angle.
    • Test the caulk on a paper towel before applying it on the surface.
    • Press the trigger on the caulking gun to release the caulk from the tube.
  5. How to fix Leaks in Shower Tiles by Caulking: adım 5, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 5, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 5, 3 resimden 3.
    • Start caulking at the top of the surface and move down along the surface.
    • Place the tip of the caulking gun on the surface between two tiles and move it down at a steady pace.
    • Go back to the top and apply the caulking on the next tile, until all of the space between the tiles has caulking.
    • Hold the caulking gun with both hands to be steady.
  6. How to fix Leaks in Shower Tiles by Caulking: adım 6, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 6, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 6, 3 resimden 3.
    • Using a damp finger, smoothen the caulking on the surface.
    • Keep a rag nearby to periodically wipe off any excess caulking.
    • Allow the caulking to dry for five minutes, before moving on to the next part.
  7. How to fix Leaks in Shower Tiles by Caulking: adım 7, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 7, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 7, 3 resimden 3.
    • Now, apply the caulking in the horizontal direction.
    • Repeat the process in Step 5 and 6.
    • Allow the caulking to dry for 5 minutes before moving to the next part.
  8. How to fix Leaks in Shower Tiles by Caulking: adım 8, 2 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 8, 2 resimden 2.
    • Go over any areas that were missed or that don't have enough caulking.
    • Put a pea size amount of caulking in that area and smoothen it out with a damp finger.
  9. How to fix Leaks in Shower Tiles by Caulking: adım 9, 3 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 9, 3 resimden 2. How to fix Leaks in Shower Tiles by Caulking: adım 9, 3 resimden 3.
    • Let the surface dry for 20 minutes.
    • After the caulking has dried, remove the excess using a putty knife.
    • To avoid scratches while removing the excess, lay the scrapper flat towards the surface.
  10. How to fix Leaks in Shower Tiles by Caulking: adım 10, 2 resimden 1. How to fix Leaks in Shower Tiles by Caulking: adım 10, 2 resimden 2.
    • In case there is still any excess, scrub over the scraped area with a damp cloth.
    • If there is any caulking left over, cover the tip of the caulking tube with a paper towel and store for later use.
    • The caulking tube can be left in the caulking gun or taken out by performing step 4 backward.
Sonuç
Clean the surface and completely let it dry before using it. It may take up to a full day to dry completely, so be prepared to not use the surface for a while!
Bir başkası bu kılavuzu tamamladı.
Suman Grewal
208 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 1,825
