Ana içeriğe geç
How to fix Logitech Anywhere MX Phantom Double Click
Neye ihtiyacın var
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: adım 1, 1 resimden 1.
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: adım 2, 1 resimden 1.
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: adım 3, 1 resimden 1.
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: adım 4, 1 resimden 1.
    • Put a piece of tape over the groove.
Sonuç
63 farklı kişi bu kılavuzu tamamladı.
Stefan Magometschnigg
1.957 İtibar
2 adet Kılavuz yazıldı
43Kılavuz Yorumları
Worked well for me, lets see how long it'll last.
Wynadorn - Yanıt
Worked for me too...saved a great little mouse!
jcrhino - Yanıt
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - Yanıt
Thank you, it worked!
Jakab Ponoczky - Yanıt
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 289
Her zaman: 50,538
