Ana içeriğe geç
How to fix PS5 overheating
Neye ihtiyacın var
Videoya Genel Bakış
    • Backup PS5 if possible
    • Gracefully shutdown the PS5
    • Unplug all cables and move to a clean working area.
    • Gather required tools
    • TR8 Torx(security bit)
    • P1 Screw Driver
    • Magnetic Project Mat
    • Plastic prying tools and Spudger.
    FixBot'a Sor
    Yorum Ekle
    • Remove Optical side cover
    • If the optical drive is closest to you, lift up on top left corner.
    • Clean accessible areas with a non-static brush, compressed-air, or vacuum.
    • When finished, flip over to remove PS logo side panel.
    FixBot'a Sor
    Yorum Ekle
    • Remove cover by gently pulling up on corner by PS logo a sliding towards the Vertical Botton of PS5.
    • Clean area as much as possible
    • Now flip the ps5 back over to the optical bay side.
    FixBot'a Sor
    Yorum Ekle
    • Using a spludger tool:
    • Carefully pry inlet grill from top-left to bottom right.
    FixBot'a Sor
    Yorum Ekle
    • Remove Molex connection cover using flat end of plastic probe
    FixBot'a Sor
    Yorum Ekle
    • Using two spludgers
    • Pry either side of the fan molex connector to disconnect.
    • TR8 Bit: Remove 4 x screws
    • 2x Screw w/ machine threads top-right and bottom-right (23.3mm)
    • 1x Short screw with coarse threads on bottom left (11.4mm)
    • 1x Long screw w/ coarse threads on top-left (31mm)
    • Remove fan cover
    • Remove fan assembly
    FixBot'a Sor
    Yorum Ekle
    • If heavy accumulation of dust is present on heatsink, proceed with further disassembly.
    FixBot'a Sor
    Yorum Ekle
    • Use P1 bit driver to remove 1 x Screw
    • Remove m.2 cover plate and set aside.
    FixBot'a Sor
    Yorum Ekle
    • Disconnect 2x Molex connectors
    FixBot'a Sor
    Yorum Ekle
    • Proceeding further will void your manufacturer warranty. Proceed at your own risk!
    • Remove stick to reveal TR8 bit head screw
    FixBot'a Sor
    Yorum Ekle
    • TR8 Bit: Remove 11 x screws
    • These screws vary in sizes so pay attention to where they go.
    • Remove cover.
    FixBot'a Sor
    Yorum Ekle
    • Use spudger to depress metal clip for ribbon cable connecting from the main unit to the optical drive.
    • The optical drive can now be removed and set aside.
    FixBot'a Sor
    Yorum Ekle
    • Remove 3x Ribbon Cables
    • Remove 2 x uFL Wifi
    • RW & RB
    • FW & FB
    FixBot'a Sor
    Yorum Ekle
    • Remove 41 X Torx Screws (Silver Screws)
    • Remove 1 X Torx Black Screw
    FixBot'a Sor
    Yorum Ekle
    • Disconnect Ribbon Cable
    • Flip over
    • Remove 2 x Torx Screws (29.4mm)
    • Remove Cover
    FixBot'a Sor
    Yorum Ekle
    • Remove Power Supply by pulling up
    FixBot'a Sor
    Yorum Ekle
    • Follow these steps in reverse or follow above video.
    FixBot'a Sor
    Yorum Ekle
Sonuç
29 farklı kişi bu kılavuzu tamamladı.
Arty
33.412 İtibar
110 adet Kılavuz yazıldı
16Kılavuz Yorumları
Thanks for the great guide which I have been using with success. I wonder if you know specifically what compound (not pads) there is on the capacitors and ram under the shield. Thank you
Ander x - Yanıt Paylaş
Thanks! Man that was alot of screws!
RadioShack SLO - Yanıt Paylaş
Awesome video, and one that showed you how to put it back together!! much appreciated sir
Alex Blackwood - Yanıt Paylaş
This was my second time tearing down the PS5 to clean it... and it was still a very annoying process.
It was made much easier with this guide, though. Thanks for all the work you put in to making it! Much appreciated.
Matthew D. H. - Yanıt Paylaş
Now it's my 3rd time using this guild to tear down the PS5. Greatly appreciate the time & effort that went to in making this guide... It's the gift that keeps on giving!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 118
Son 7 gün: 912
Son 30 gün: 4,560
Her zaman: 177,685
