Ana içeriğe geç
How to fix TC Electronic Level Pilot static noise
Neye ihtiyacın var
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: adım 1, 1 resimden 1.
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: adım 2, 1 resimden 1.
    • Spray the small opening with electrical contact cleaner.
    • Only use electrical cleaning spray.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Alpha Dimension
409 İtibar
1 Kılavuz yazıldı
6Kılavuz Yorumları
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Yanıt
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Yanıt
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Yanıt
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Yanıt
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 6,199
