Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Nothing special, just to open the level pilot and repair it.
Neye ihtiyacın var
The bottom rubber base can be removed
11 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Not a good idea. Oil will &&^& it up dah.
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
Yes, use DeOxit or some similar contact cleaner
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
