Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Check for any screws that may have become loose over time in your door hinges.
If you found any loose screws on the door hinge, use your screwdriver to tighten them.
Examine the faceplate, checking for any loose screws like you did with your door hinges.
Use your screwdriver to tighten any loose screws found on the face plate.
This is your strike plate. Take a look to see if it has shifted, and in what direction it shifted.
In the photo provided you can tell my plate has been shifted downwards.
Make a line on the wall where you will be moving your strike plate. Use something that you will be able to remove, such as a pencil.
Take as many toothpicks you will need to fill up the holes that were created for the previous screw holes, and dip them into the Elmer's glue.
Place the toothpicks into the openings. By doing this, you are preventing your new screws from falling back into the old spot causing the door to be re-positioned again.
5 farklı kişi bu kılavuzu tamamladı.
