Ana içeriğe geç
How to fix a blown heater element in a Toaster
Neye ihtiyacın var
Videoya Genel Bakış
    • Insert wisdom here.
    • how to fix a toaster
Sonuç
Not too difficult, you need patience though.
5 farklı kişi bu kılavuzu tamamladı.
jon
3.210 İtibar
22 adet Kılavuz yazıldı
2Kılavuz Yorumları
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Yanıt
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 69
Her zaman: 26,761
