Giriş
The blown element stops the toaster working, but the wires can be rejoined over the blown section, with very little detrimental effect. See this fix in this video guide
Neye ihtiyacın var
Videoya Genel Bakış
Not too difficult, you need patience though.
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
Thanks for this video, which helped a lot in repairing my toaster!
In the end I found that rather than twisting the two broken ends of the element together a neater fix was to simply cut far enough to make enough ‘extra’ element to overlap as far as the holding strip (and a bit beyond). Overlap by sliding one end in the opposite direction to the other under the nearest existing vertical strip (the strips that are there to keep the element in place.) This was enough to keep them in contact in my toaster without creating a ‘knot’, and is almost an invisible fix.
Hope this comment helps someone else. Thanks again for this great site.
M Bird - Yanıt
