Ana içeriğe geç
How to fix a broken infill on a ProtoCentre 999
Neye ihtiyacın var
    • Open kissliser
    • click on style
    • Decrease the infill density to a value of around 20% is normal
    • Go to the machine main menu.
    • There you can see the print speed in percentage.
    • Reduce the print speed in between a value of 50% to 100%.
    • Open kisslicer
    • Go to style
    • change the infill pattern to straight,octagonal, rounded based on the kind of print you are going on with.
    • In some case , the filament may stick on the nozzle tip and while going for the print, the filament sticked will hit the infill and cause infill to break.
    • Remove the sticked filament from the nozzle with the help of a needle tip,
Sonuç
abhishek j
1.193 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 9
Her zaman: 49
