Giriş
If you have a MIDI controller with keys that don't function correctly, it's often due to dust or a faulty connection. This guide can help fix it. Here's a quick and easy way to fix a broken key on an Akai MPK mini keyboard in under 20 minutes!
Neye ihtiyacın var
Be sure to identify which key isn't working. For me, it was the first key, or the "C" key on the keyboard.
To reassemble your device, plug in device and test your key.Finally, turn off your device, put the keys and cover back on and rescue the screw as you did before.
Bir başkası bu kılavuzu tamamladı.
