Ana içeriğe geç
How to fix a jammed nozzle on a ProtoCentre 999
Neye ihtiyacın var
  1. How to fix a jammed nozzle on a ProtoCentre 999, PREHEATING THE MACHINE: adım 1, 3 resimden 1. How to fix a jammed nozzle on a ProtoCentre 999, PREHEATING THE MACHINE: adım 1, 3 resimden 2. How to fix a jammed nozzle on a ProtoCentre 999, PREHEATING THE MACHINE: adım 1, 3 resimden 3.
    • ON the power switch.
    • Go to prepare .
    • Click the option , preheat.
    • Go back to the main menu, check whether the nozzle temperature is increasing to the set temperature.
  2. How to fix a jammed nozzle on a ProtoCentre 999, REMOVE TEFLON TUBE: adım 2, 3 resimden 1. How to fix a jammed nozzle on a ProtoCentre 999, REMOVE TEFLON TUBE: adım 2, 3 resimden 2. How to fix a jammed nozzle on a ProtoCentre 999, REMOVE TEFLON TUBE: adım 2, 3 resimden 3.
    • Remove the teflon tube from the nozzle block.
    • In some case the teflon tube will not come out free. In this case, increase the temperature to 280 deg and try to remove the teflon tube.
  3. How to fix a jammed nozzle on a ProtoCentre 999, CLEENING WITH NEEDLE: adım 3, 3 resimden 1. How to fix a jammed nozzle on a ProtoCentre 999, CLEENING WITH NEEDLE: adım 3, 3 resimden 2. How to fix a jammed nozzle on a ProtoCentre 999, CLEENING WITH NEEDLE: adım 3, 3 resimden 3.
    • Take the needle, and try to clean it from the top of the nozzle block.
    • In some case, jammed filament will not come out free. At this case , increase the nozzle temperature to 280deg and remove the nozzle cooler fan.
    • And try to clean the nozzle from the top with the help of a needle and a nose plier.
    • If the nozzle is again not clean, try to clean the nozzle by removing the nozzle tip with the help of a nose plier and spanner. Again clean it with the help of a needle.
    • NOTE: Be careful while removing the nozzle tip. If you extract more pressure on the nozzle tip, it may break. So be careful while doing it.
  4. How to fix a jammed nozzle on a ProtoCentre 999, REASSEMBLE.: adım 4, 2 resimden 1. How to fix a jammed nozzle on a ProtoCentre 999, REASSEMBLE.: adım 4, 2 resimden 2.
    • Reassemble the nozzle tip again with the help of the nose plier and spanner after cleaning the nozzle.
    • Reinsert the teflon tube.
  5. How to fix a jammed nozzle on a ProtoCentre 999, CHECKING OF EXTRUSION: adım 5, 3 resimden 1. How to fix a jammed nozzle on a ProtoCentre 999, CHECKING OF EXTRUSION: adım 5, 3 resimden 2. How to fix a jammed nozzle on a ProtoCentre 999, CHECKING OF EXTRUSION: adım 5, 3 resimden 3.
    • Go to prepare
    • click on move axis
    • Select the extrude
    • Rotate the knob in clock wise direction and check the extrusion.
  6. How to fix a jammed nozzle on a ProtoCentre 999, GO FOR PRINT: adım 6, 1 resimden 1.
    • Now you can go for the print .
Sonuç
abhishek j
1.193 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 113
