Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
How to fix a leaking garbage disposal at flange
Neye ihtiyacın var
  1. How to fix a leaking garbage disposal at flange, How to fix a leaking garbage disposal at flange: adım 1, 2 resimden 1. How to fix a leaking garbage disposal at flange, How to fix a leaking garbage disposal at flange: adım 1, 2 resimden 2.
    • Unplug the garbage disposal from the power source.
    • Be sure to place the wall plug in a dry location for the duration of the fix.
  2. How to fix a leaking garbage disposal at flange: adım 2, 2 resimden 1. How to fix a leaking garbage disposal at flange: adım 2, 2 resimden 2.
    • Loosen and disconnect the dishwasher drain hose from the garbage disposal unit.
    • Do so by loosening the clamp and unscrewing the screws with a flathead screwdriver.
    • Remove the screws and pull the gray tube from the disposal.
  3. How to fix a leaking garbage disposal at flange: adım 3, 2 resimden 1. How to fix a leaking garbage disposal at flange: adım 3, 2 resimden 2.
    • Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
    • Disconnect lock-nut at flange.
    • Adequate lighting is imperative for this step.
  4. How to fix a leaking garbage disposal at flange: adım 4, 2 resimden 1. How to fix a leaking garbage disposal at flange: adım 4, 2 resimden 2.
    • Use screwdriver to turn locking ring counter clock-wise disengaging drain hose and disposal.
    • You will be able to hear the locking ring come undone after pushing it forcefully to the left.
    • Disposal will drop down. When disposal falls catch and place on bottom of sink.
    • Move from underneath the sink to the top of the sink.
  5. How to fix a leaking garbage disposal at flange: adım 5, 2 resimden 1. How to fix a leaking garbage disposal at flange: adım 5, 2 resimden 2.
    • To remove flange you will push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
    • Scrape off ALL excess putty from flange and sink.
  6. How to fix a leaking garbage disposal at flange: adım 6, 3 resimden 1. How to fix a leaking garbage disposal at flange: adım 6, 3 resimden 2. How to fix a leaking garbage disposal at flange: adım 6, 3 resimden 3.
    • Remove small ball of putty and roll into golf ball shape.
    • Roll flat until putty becomes snakelike shape approximately 3/4 inch diameter.
    • Be sure that putty is long enough to wrap completely around flange.
  7. How to fix a leaking garbage disposal at flange: adım 7, 2 resimden 1. How to fix a leaking garbage disposal at flange: adım 7, 2 resimden 2.
    • Roll into snake-like shape until long enough to fit fully around flange.
    • Wrap around flange and place flange back into sink.
    • Press down hard into sink and remove any excess Plumber's Putty.
  8. How to fix a leaking garbage disposal at flange: adım 8, 1 resimden 1.
    • Reassemble flange and garbage disposal reversing steps.
    • Put sink stopper in and fill up sink approximately halfway. Remove stopper and check underneath sink for leak.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amy Haren
175 İtibar
1 Kılavuz yazıldı
Bir Yorum
How do you stop the flange screws from backing out? Fixed it yesterday and screws were loose already this evening…help…
Mike T - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 105
Her zaman: 6,211
