Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Loosen and disconnect the dishwasher drain hose from the garbage disposal unit by loosening the clamp and removing the screws with a flathead screwdriver.
Pull the gray tube from the disposal.
Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
Disconnect the lock-nut at the flange.
Use the screwdriver to turn the locking ring counter clock-wise, disengaging the drain hose and disposal.
The disposal will drop down—be sure to catch the disposal and place on the bottom of the sink.
Move from underneath the sink to the top of the sink.
To remove the flange, push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
Scrape off ALL excess putty from the flange and the sink.
Remove a small ball of putty and roll into a golf ball shape.
Roll the putty flat into a snakelike shape, approximately 3/4 inch diameter.
Wrap the putty around the flange and place the flange back into the sink.
Press down hard into the sink and remove any excess Plumber's Putty.
Reassemble the flange and garbage disposal by reversing these steps.
Put a sink stopper in and fill up the sink approximately halfway.
Remove the stopper and check underneath the sink to make sure there are no leaks.
Bir başkası bu kılavuzu tamamladı.
