Ana içeriğe geç
How to fix boot loop in Xiaomi Redmi Note 3
Neye ihtiyacın var
Videoya Genel Bakış
Xiaomi Redmi Note 3 repair boot loop after water damage
  1. How to fix boot loop in Xiaomi Redmi Note 3, Motherboard: adım 1, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3, Motherboard: adım 1, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3, Motherboard: adım 1, 3 resimden 3.
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the phone's top edge.
    • Press gently to eject the SIM tray
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. How to fix boot loop in Xiaomi Redmi Note 3: adım 2, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 2, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 2, 3 resimden 3.
    • Insert a putty knife or opening tool into the seam between the phone's back cover and front cover.
    • Run the opening tool along the seam to loosen the back cover.
    • It may take quite a bit of prying and wiggling to remove the back cover.
    • Open the back cover slightly so that you can see the flex cable connected between both halves of the phone.
    • The flex cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  3. How to fix boot loop in Xiaomi Redmi Note 3: adım 3, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 3, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the flex cable using the flat end of a spudger or a pair of tweezers.
    • Remove the phone's back cover.
    • To reconnect the flex cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  4. How to fix boot loop in Xiaomi Redmi Note 3: adım 4, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five screws in the plastic covering at the bottom of the device.
  5. How to fix boot loop in Xiaomi Redmi Note 3: adım 5, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 5, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 5, 3 resimden 3.
    • Insert the flat end of a spudger under the plastic assembly cover at the bottom of the device.
    • Pry upwards with the spudger to lift the assembly cover.
    • Remove the assembly cover.
  6. How to fix boot loop in Xiaomi Redmi Note 3: adım 6, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 6, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the battery flex cable from the lower assembly.
    • Use the flat end of a spudger to disconnect the ribbon cable on the left-hand side of the device.
  7. How to fix boot loop in Xiaomi Redmi Note 3: adım 7, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 7, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger under the assembly at the bottom of the device near the right-hand corner.
    • Pry upwards with the spudger to release the right-hand corner of the assembly.
    • Insert the flat end of a spudger under the assembly at the bottom of the device near the left-hand corner.
    • Pry upwards with the spudger to release the left-hand corner of the assembly.
    • Use your fingers to remove the assembly.
  8. How to fix boot loop in Xiaomi Redmi Note 3: adım 8, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 8, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 8, 3 resimden 3.
    • Peel back the barcode sticker so that it is disconnected from the battery.
    • Use your fingers to grasp the black battery adhesive tab and pull outwards firmly until the entire adhesive strip is released.
    • Repeat for the second battery adhesive strip.
  9. How to fix boot loop in Xiaomi Redmi Note 3: adım 9, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 9, 2 resimden 2.
    • Insert the flat end of a spudger underneath the battery.
    • Use your fingers to remove the battery.
  10. How to fix boot loop in Xiaomi Redmi Note 3: adım 10, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 10, 2 resimden 2.
    • Use a spudger to disconnect all marked ribbon cables.
  11. How to fix boot loop in Xiaomi Redmi Note 3: adım 11, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 11, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the eight screws fastening the motherboard to the phone's interior.
  12. How to fix boot loop in Xiaomi Redmi Note 3: adım 12, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 12, 2 resimden 2.
    • Use a pair of tweezers to remove the small metal piece from the top of the motherboard.
  13. How to fix boot loop in Xiaomi Redmi Note 3: adım 13, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 13, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 13, 3 resimden 3.
    • Slide an opening tool underneath the plastic assembly covering the upper portion of the motherboard.
    • Use your fingers or the opening tool to remove the plastic covering.
  14. How to fix boot loop in Xiaomi Redmi Note 3: adım 14, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 14, 2 resimden 2.
    • Slide an opening tool or the flat end of a spudger underneath the motherboard.
    • Pry upwards to loosen the motherboard from the phone's front cover.
  15. How to fix boot loop in Xiaomi Redmi Note 3: adım 15, 3 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 15, 3 resimden 2. How to fix boot loop in Xiaomi Redmi Note 3: adım 15, 3 resimden 3.
    • Gently lift the motherboard from its slot.
    • Use the flat end of a spudger to disconnect the cable from the bottom of the motherboard.
  16. How to fix boot loop in Xiaomi Redmi Note 3: adım 16, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3: adım 16, 2 resimden 2.
    • Use your fingers to remove the motherboard.
  17. How to fix boot loop in Xiaomi Redmi Note 3, How to fix boot loop in Xiaomi Redmi Note 3: adım 17, 2 resimden 1. How to fix boot loop in Xiaomi Redmi Note 3, How to fix boot loop in Xiaomi Redmi Note 3: adım 17, 2 resimden 2.
    • Visually inspect the phone's motherboard for any corrosion.
    • Apply a small amount of flux to the corroded parts of the motherboard using a brush.
    • Wipe away any corrosion using a soft brush.
  18. How to fix boot loop in Xiaomi Redmi Note 3: adım 18, 1 resimden 1.
    • Place a heat shield over the other parts of the motherboard to avoid overheating.
    • Heat the affected area with a heat gun to reflow the solder.
    • Reflowing heats up all the soldering joints in an area so they become liquid enough to reinforce the bonds. This allows electricity to flow through the bond without unexpected resistance.
  19. How to fix boot loop in Xiaomi Redmi Note 3: adım 19, 1 resimden 1.
    • Apply a small amount of isopropyl alcohol to the affected areas.
    • The isopropyl alcohol will clean any remaining flux that was not burned off during the heating process.
  20. How to fix boot loop in Xiaomi Redmi Note 3: adım 20, 1 resimden 1.
    • Repeat steps 11-13 for any other areas of the motherboard that are corroded or rusty.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alex Sander
39.114 İtibar
201 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 10,114
