Ana içeriğe geç
How to fix stuck Joy-Con Triggers
Neye ihtiyacın var
  1. How to fix stuck Joy-Con Triggers, Removing Cover Screws: adım 1, 1 resimden 1.
    • Using the Tri-Point Screwdriver, remove the 4 screws keeping the Joy-Con's shell together.
  2. How to fix stuck Joy-Con Triggers, Opening the Joy-Con: adım 2, 1 resimden 1.
    • Lift the shell to reveal the internals of the Joy-Con
    • If you are fixing the opposite-side Joy-Con, it will appear to be a mirror image
  3. How to fix stuck Joy-Con Triggers, Locate the Button: adım 3, 1 resimden 1.
    • Locate the ZR or ZL Button inside the Joy-Con Controller
  4. How to fix stuck Joy-Con Triggers, Positioning the Button: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to lift the ZL button, then put it back into it's correct position
    • Put the button in a position where clicking is possible
  5. How to fix stuck Joy-Con Triggers, Place the Shell back on the Joy-Con: adım 5, 1 resimden 1.
    • Using the Tri-Point screwdriver, put the 4 screws back into place.
Sonuç
Congratulations, you did it!
5 farklı kişi bu kılavuzu tamamladı.
Russell Repair Co.
2.258 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 102
Son 30 gün: 481
Her zaman: 8,521
