Ana içeriğe geç
How to fix the power button on a Synology DS212J
Neye ihtiyacın var
  1. How to fix the power button on a Synology DS212J, How to fix the power button on a Synology DS212J: adım 1, 1 resimden 1.
    • Power down the Synology.
    • Since the power button no longer works you can go to the web interface [https://IP_address:5001], log in and select shutdown from the menu in the top right.
  2. How to fix the power button on a Synology DS212J: adım 2, 1 resimden 1.
    • Remove two screws from the back.
    • Make sure to put these screws where you can find them, mine are long gone!
    • Slide the side of the enclosure forward.
  3. How to fix the power button on a Synology DS212J: adım 4, 1 resimden 1.
    • As you can see the plastic of the power button has broken of.
    • I considered replacing the button but fabricobbled an easier fix.
  4. How to fix the power button on a Synology DS212J: adım 5, 1 resimden 1.
    • Remove the gray front with 3 screws for easier access.
    • Cut a bit of thin plastic to the right dimensions. (About 3 x 1 mm)
    • Superglue the thin plastic on the cross of the power button.
    • Re-assemble and if all is well you have a working power button!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rogier Gerritse
160 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 1,729
