Giriş
In order to flash the firmware of the System Controller, you need another computer and a USB cable. Depending on the revision of your Reform, you may need either a Micro-USB or a USB type-C cable.
You will also need the firmware, which can be downloaded from the reform2-lpc-fw folder in the main Reform repository.
Neye ihtiyacın var
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Use a spudger or your fingernail to set the DIP switch LPCP to ON.
Use a spudger or your finger to press the LPCRST button next to the DIP switch from the previous step.
Plug the other end of the cable into another computer. The system controller's memory appears as a virtual flash drive on that computer.
Open a terminal and navigate to the reform2-lpc-fw folder you've downloaded from the Reform repository.
Check lsblk or dmesg -w to find out which drive the LPC shows up as, then edit flash.sh with the correct path to the virtual flash drive (e.g. /dev/sdx).
Execute flash.sh as root.
Use a spudger or your fingernail to set the DIP switch LPCP to OFF, which is the side labeled "1".
To reassemble your device, follow steps 1 and 2 in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
Bir başkası bu kılavuzu tamamladı.
