Ana içeriğe geç
How to manually Unload Filament on an Ender 3 Pro
  1. How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: adım 1, 3 resimden 1. How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: adım 1, 3 resimden 2. How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: adım 1, 3 resimden 3.
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. How to manually Unload Filament on an Ender 3 Pro, Wait for the hotend to heat up: adım 2, 1 resimden 1.
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. How to manually Unload Filament on an Ender 3 Pro, Pull the filament: adım 3, 1 resimden 1.
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. How to manually Unload Filament on an Ender 3 Pro, Set cooldown: adım 4, 1 resimden 1.
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
Sonuç
This guide also applies to loading filament. You just need to push in the filament instead of pulling it out.
Bir başkası bu kılavuzu tamamladı.
Sebastian
31.160 İtibar
71 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 54
Her zaman: 2,043
