Giriş
This guide provides detailed instructions to disassemble your multimeter, allowing you to access internal components for maintenance or repair purposes.
Neye ihtiyacın var
Place the multimeter on its front.
Flip up the kickstand.
Use a PH1 screwdriver to unscrew the single screw holding the battery cover and kickstand.
Remove the battery cover and kickstand.
Remove the batteries, if present.
Use a PH1 screwdriver to unscrew the four screws holding the back cover.
Insert a pick into the top gap between the backshell and front cover.
Partly leverage the front cover away from the backshell.
Insert a pick into the bottom gap between the backshell and front cover.
Fully leverage the front cover out of the backshell.
