Giriş
The USB Rubber Ducky is a powerful hacking tool, but to modify or repair it, you'll need to open the case.
In this guide, we'll show you how to safely open the case of your USB Rubber Ducky.
Neye ihtiyacın var
First remove the the USB-C cap
Jam a flat object, such as your fingernail or a small screwdriver, in between the metal sheath and the Ducky on both sides.
Remove the metal sheath by pulling it off the Ducky.
Bu adımda kullanılan alet:iFixit Opening Picks (Set of 6)$4.99
Carefully separate the top and bottom plastics by inserting a plastic pick at the seam.
Bir başkası bu kılavuzu tamamladı.
