Ana içeriğe geç
How to reboot the Flipper Zero
Neye ihtiyacın var
      • Press the Back- and Left-buttons at the same time.
      • This is a hardware reboot that triggers the CPU to restart firmware. Even when the operating system does not respond, the hardware restart will still work.
      FixBot'a Sor
      Yorum Ekle
      • In this mode, Flipper Zero activates the bootloader and is detected in the computer as a DFU device. When the firmware is updated, Flipper Zero enters the recovery mode on its own. To exit this mode, perform a reboot.
      • Release the Back-button but don't release the Left-button until the blue LED lights up.
      FixBot'a Sor
      Yorum Ekle
      • If the bootloader is damaged, rebooting to update mode will not work. There will be no image on Flipper Zero's screen and the status LED will not work. In this case, only the full recovery mode will help to restore the device.
      • Disconnect Flipper Zero from USB.
      • Press and hold the OK- and Back-buttons for 30 seconds.
      • Connect the device to your computer.
      FixBot'a Sor
      Yorum Ekle
      • Go to Main Menu > Settings > Power > Reboot.
      • Select Flipper OS, and then press the OK-button.
      FixBot'a Sor
      Yorum Ekle
      • Connect your Flipper Zero to your PC.
      • Open Putty or a similar application.
      • Connect to the Flipper Zero COM port at 115200 bauds.
      • Enter the reboot-command and press Enter.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Have fun!
6 farklı kişi bu kılavuzu tamamladı.
Sebastian
33.637 İtibar
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 44
Son 30 gün: 165
Her zaman: 28,080
