Ana içeriğe geç
How to recover accidentally removed data from NAS
Neye ihtiyacın var
  1. How to recover accidentally removed data from NAS, How to recover accidentally removed data from NAS: adım 1, 1 resimden 1.
    • Take the disks out of the NAS device and connect them to a Windows computer.
  2. How to recover accidentally removed data from NAS, To initialize or format?: adım 2, 1 resimden 1.
    • If the operating system of the computer to which you have connected the disks asks you to initialize or format them, don’t do that, because it will make recovery a lot more complicated.
  3. How to recover accidentally removed data from NAS: adım 3, 1 resimden 1.
    • Run Hetman RAID Recovery. It will analyze the disks, read their service information and rebuild the damaged RAID system. Below, you can see detailed information about the array and check if the program has identified it correctly.
  4. How to recover accidentally removed data from NAS, Start a scan: adım 4, 3 resimden 1. How to recover accidentally removed data from NAS, Start a scan: adım 4, 3 resimden 2. How to recover accidentally removed data from NAS, Start a scan: adım 4, 3 resimden 3.
    • To start a scan, right-click on the disk and choose “Open”. Select the scan type and click Next to start it.
  5. How to recover accidentally removed data from NAS, The program has rebuilt the damaged RAID: adım 5, 1 resimden 1.
    • As you can see, the program has rebuilt the damaged RAID easily and found all the files stored on the network drive. If you are looking for files that have been removed, you can identify them by red crosses.
  6. How to recover accidentally removed data from NAS, Select all the items you want to recover: adım 6, 2 resimden 1. How to recover accidentally removed data from NAS, Select all the items you want to recover: adım 6, 2 resimden 2.
    • Select all the items you want to recover, click Recovery, select where you want to save them. When the recovery process is over, you’ll find all of the files in the folder you have chosen.
  7. How to recover accidentally removed data from NAS, How to recover data from an iSCSI disk: adım 7, 2 resimden 1. How to recover accidentally removed data from NAS, How to recover data from an iSCSI disk: adım 7, 2 resimden 2.
    • If files are deleted accidentally from an iSCSI disk, you don’t have to take the hard disks out of the NAS device and connect them to a computer – just run our program and scan the network drive.
  8. How to recover accidentally removed data from NAS, How to rebuild a damaged array manually with the RAID Constructor: adım 8, 1 resimden 1.
    • When a disk is damaged or service information is erased, the program may have difficulty in automating the rebuild process. If the program failed to rebuild the array but you know its properties, you can perform this operation manually, with the help of the RAID Constructor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Denver Dela Cruz
1 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
If you have any questions about recovering data from NAS, leave a comment to ask.
Denver Dela Cruz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 74
Her zaman: 143
