Giriş
It is time to do a wheel distribution if you notice that your skates are less balanced, stop poorly, and that your wheels are not symmetrical. Wheel distribution is a free alternative to buying a brand new set of wheels, and an important part of basic skate maintenance.
Neye ihtiyacın var
Set up the skates on a surface that is okay to get a little messy.
The wheels shown in the third photo are very heavily worn. It may be best to simply replace the wheels at this point.
Do a final check of your skate. This is a very important step, as an improperly aligned screw is easily missed but can fall out very easily.
The rubber surrounding the plastic of the wheels broke off today and I need them replaced but I'd what size I need
All wheels should spin freely. Adding the wheels back into the frame are trickier than getting them out and play a bigger role in your personal safety, so make sure to do that final check. Hopefully, the redistributed wheels will bring back some life into your old skates!
Bir başkası bu kılavuzu tamamladı.
3 Yorum
do you fix vive headset
vive headset strap. snap on
I can get one side of the bolts off but not the other side. They just keep spinning when I try to loosen them. Any ideas on how to get the rest of the bolts out?
