Ana içeriğe geç
How to remove FHX-720bt head unit in a 1999-2007 Chevrolet Silverado
Neye ihtiyacın var
  1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 1, 2 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 1, 2 resimden 2.
    • Locate the hood latch in your vehicle found on the drivers side under the dashboard to the left of the parking brake pedal.
    • Pull the latch to release hood.
  2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 2, 3 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 2, 3 resimden 2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 2, 3 resimden 3.
    • Locate the release latch for the hood in between the grille and hood, directly above the "GMC" logo at the front of the car.
    • Lift up on the latch then raise the hood.
  3. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 3, 2 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 3, 2 resimden 2.
    • Locate your battery in the front of the engine compartment near the headlight, on the driver's side.
    • Remove the black negative terminal with 5/16" socket or by using a 5/16" wrench.
    • BE CAREFUL. DO NOT CROSS POSITIVE AND NEGATIVE WIRES.
  4. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 4, 2 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 4, 2 resimden 2.
    • Make sure the vehicle is on a flat surface, then use the parking brake.
    • Shift vehicle into 1st gear so the shifter will be out of the way for the next step.
  5. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 5, 3 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 5, 3 resimden 2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 5, 3 resimden 3.
    • Firmly grasp the top of the dash trim and pull it towards you.
    • Once it is removed from its clips, pull up and the trim will come out the rest of the way.
    • Set the trim aside; you are ready for the next step.
  6. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 6, 2 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 6, 2 resimden 2.
    • Remove the face plate from the head unit.
    • To do this, pull out on both the left and right sides to release the face plate from its clips.
    • After being released from the clips, set the face plate aside and continue to the next step.
  7. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 7, 3 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 7, 3 resimden 2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 7, 3 resimden 3.
    • Remove three bolts using a 7mm socket wrench, two on the left and one on the right.
  8. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 8, 3 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 8, 3 resimden 2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 8, 3 resimden 3.
    • Remove the head unit once the bolts have been taken out.
  9. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 9, 2 resimden 1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: adım 9, 2 resimden 2.
    • Place the head unit face down to allow the wires on the back to be visible and more easily accessible.
    • Listed below are the wires coming connected to the head unit. The colors correspond to the same color of the wire.
    • RCA inputs
    • Microphone input/wire
    • Power/audio/assorted control wire harness
    • Antenna input/wire
    • Harness disconnect
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Justin Reiner
317 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-1, Green Fall 2015 Cal Poly, Team 15-1, Green Fall 2015 üyesi
CPSU-GREEN-F15S15G1
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 1,760
