Ana içeriğe geç
How to remove a stuck bike seat post without destroying the post
Neye ihtiyacın var
Videoya Genel Bakış
  1. How to remove a stuck bike seat post without destroying the post, How to remove a stuck bike seat post without destroying the post: adım 1, 1 resimden 1.
    • For Tools you will need a saw, socket set, drill, wire brush drill bit that inside the post sleeve and a long drill bit extension.
    • For parts you will need about a foot of stout chain, two quick links, 1/4" #8 steel bolt/washers/nut long enough to go through the seat post, two 1/4" steel bolts/washers/nuts at least 5 1/2" long to hold the 2x4s together at the base and a huge eye bolt and a 8' 2x4 stud. all can be bought at your local hardware store.
    • Look for a rating of at least 1000lb in all the parts you buy. they are low cost and that way you don't need to worry about things snapping.
    • cut a 5" section of 2x4 and drill a hole in the middle for the eye bolt.
Sonuç
Gabe
318 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 2,027
