Ana içeriğe geç
How to remove burnt stains on pans
Neye ihtiyacın var
  1. How to remove burnt stains on pans, How to remove burnt stains on pans: adım 1, 2 resimden 1. How to remove burnt stains on pans, How to remove burnt stains on pans: adım 1, 2 resimden 2.
    • Prepare your workstation by making sure you have all the listed tools. Next, ensure the burnt pan is cool before starting the process. Remove any loose debris or food particles from the pan.
  2. How to remove burnt stains on pans, Baking Soda Application: adım 2, 2 resimden 1. How to remove burnt stains on pans, Baking Soda Application: adım 2, 2 resimden 2.
    • Sprinkle a generous amount of baking soda over the burnt areas of the pan. Use enough baking soda to cover the stains fully.
  3. How to remove burnt stains on pans: adım 3, 1 resimden 1.
    • Sprinkle salt over the baking soda. Salt acts as an abrasive agent and enhances the cleaning process.
  4. How to remove burnt stains on pans: adım 4, 2 resimden 1. How to remove burnt stains on pans: adım 4, 2 resimden 2.
    • Pour white vinegar over the baking soda and salt mixture. The vinegar will react with the baking soda, creating a foaming action that helps loosen the burnt stains.
  5. How to remove burnt stains on pans: adım 5, 2 resimden 1. How to remove burnt stains on pans: adım 5, 2 resimden 2.
    • Place the pan on a stove or heat source. Heat the pan on low to medium heat for 5-10 minutes. Ensure to use your phone or a timer . The heat helps activate the cleaning ingredients and loosen the burnt stains.
  6. How to remove burnt stains on pans: adım 6, 3 resimden 1. How to remove burnt stains on pans: adım 6, 3 resimden 2. How to remove burnt stains on pans: adım 6, 3 resimden 3.
    • After heating, allow the pan to cool slightly for 6 minutes . Make sure to wear rubber gloves, and gently scrub the burnt areas with a soft sponge or scrubbing brush. Continue cleaning until the burnt stains start to lift off.
  7. How to remove burnt stains on pans: adım 7, 2 resimden 1. How to remove burnt stains on pans: adım 7, 2 resimden 2.
    • Rinse the pan thoroughly with cold water to remove any remaining baking soda, salt, and vinegar residue. Repeat the process for stubborn stains until the pan is clean.
  8. How to remove burnt stains on pans: adım 8, 1 resimden 1.
    • Stained Pan looking fresh as New !
Sonuç
To remove stains from your cooking pan, follow these step by step instructions.
Bir başkası bu kılavuzu tamamladı.
Alessia Maneli
184 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 179
