Ana içeriğe geç
How to remove scratches from an Airpods Case
Neye ihtiyacın var
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: adım 1, 2 resimden 1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: adım 1, 2 resimden 2.
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: adım 2, 1 resimden 1.
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: adım 3, 1 resimden 1.
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: adım 4, 2 resimden 1. How to remove scratches from an Airpods Case: adım 4, 2 resimden 2.
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: adım 5, 1 resimden 1.
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: adım 6, 1 resimden 1.
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: adım 7, 1 resimden 1.
    • Refreshed now!
Sonuç
This will give the charging case a refreshed look instead of a dirty, scratched surface.
30 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
zh en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Z.Heng
3.802 İtibar
3 adet Kılavuz yazıldı
8Kılavuz Yorumları
Extremely convincing, especially the last picture.
Ludger - Yanıt
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - Yanıt
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - Yanıt
How big can the scratches be ?
Albert zweisteim - Yanıt
How do you get it shiny again?
lucas cheraki - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 151
Son 30 gün: 677
Her zaman: 91,624
