Ana içeriğe geç
How to remove the back cover of the LG Extravert
Neye ihtiyacın var
  1. How to remove the back cover of the LG Extravert, Flip over phone: adım 1, 2 resimden 1. How to remove the back cover of the LG Extravert, Flip over phone: adım 1, 2 resimden 2.
    • Start by flipping over the phone
  2. How to remove the back cover of the LG Extravert, Remove cover: adım 2, 2 resimden 1. How to remove the back cover of the LG Extravert, Remove cover: adım 2, 2 resimden 2.
    • Remove the case on the back of the cell phone by pulling up on the little indent with your fingernail or a Spudger in the bottom of the phone.
  3. How to remove the back cover of the LG Extravert, Remove battery: adım 3, 3 resimden 1. How to remove the back cover of the LG Extravert, Remove battery: adım 3, 3 resimden 2. How to remove the back cover of the LG Extravert, Remove battery: adım 3, 3 resimden 3.
    • After you pull off the case, the battery is right under it. All you have to do is put you Spudger or fingernail into the indent on the right side of the battery and pull up.
  4. How to remove the back cover of the LG Extravert, Removing Screws: adım 4, 1 resimden 1.
    • Using a JIS #000 screwdriver, remove all 8 screws.
  5. How to remove the back cover of the LG Extravert, Remove the black cover.: adım 5, 1 resimden 1.
    • Using the Ifixit Opening Tool, insert it near the small indent, sliding it to the right. then pull towards the outside of the phone.
    • Be careful, as the Antennas are under the cover.
  6. How to remove the back cover of the LG Extravert, Start removing the case: adım 6, 1 resimden 1.
    • slide out the keyboard.
    • put your ring finger on the red rim around the keyboard, and your thumb on the model label.
    • push away from the phone with your index finger, and towards the phone with your thumb. there should be a small pop sound, as the casing will slightly pull from the phone.
  7. How to remove the back cover of the LG Extravert, Opening the left side: adım 7, 1 resimden 1.
    • insert a opening pick or a Ifixit opening tool into the gap your created in the last step, moving to the left.
  8. How to remove the back cover of the LG Extravert, Opening the top: adım 8, 1 resimden 1.
    • Please note this side is the most difficult due to the camera bulge.
    • insert the opening pick or Ifixit opening tool into the top left corner, and move upwards.
    • The right side should pop open most of the way when you get near the headphone jack
  9. How to remove the back cover of the LG Extravert, Opening the bottom: adım 9, 2 resimden 1. How to remove the back cover of the LG Extravert, Opening the bottom: adım 9, 2 resimden 2.
    • Turn the phone onto its backside.
    • You should be able to pull the case away, but if you can't still, insert your opening pick or ifixit opening tool into the bottom of the battery slot. Slide your tool to the right.
    • Be careful! The antenna could possibly be damaged by a harsh movement.
Sonuç
timtom77
3.146 İtibar
2 adet Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
188 Üyeler
262 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 109
