Ana içeriğe geç
How to repair a IdeaPad with faulty fingerprint
Neye ihtiyacın var
  1. How to repair a IdeaPad with faulty fingerprint, Back Panel: adım 1, 2 resimden 1. How to repair a IdeaPad with faulty fingerprint, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. How to repair a IdeaPad with faulty fingerprint: adım 2, 3 resimden 1. How to repair a IdeaPad with faulty fingerprint: adım 2, 3 resimden 2. How to repair a IdeaPad with faulty fingerprint: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. How to repair a IdeaPad with faulty fingerprint: adım 3, 2 resimden 1. How to repair a IdeaPad with faulty fingerprint: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. How to repair a IdeaPad with faulty fingerprint, Battery: adım 4, 2 resimden 1. How to repair a IdeaPad with faulty fingerprint, Battery: adım 4, 2 resimden 2.
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. How to repair a IdeaPad with faulty fingerprint: adım 5, 3 resimden 1. How to repair a IdeaPad with faulty fingerprint: adım 5, 3 resimden 2. How to repair a IdeaPad with faulty fingerprint: adım 5, 3 resimden 3.
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
Sonuç
[deleted]
221 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 40
