Ana içeriğe geç
How to repair a buckle (ski braces)
Neye ihtiyacın var
  1. How to repair a buckle (ski braces), Identify the defect: adım 1, 3 resimden 1. How to repair a buckle (ski braces), Identify the defect: adım 1, 3 resimden 2. How to repair a buckle (ski braces), Identify the defect: adım 1, 3 resimden 3.
    • The buckle stitching is broken, and the buckle has fallen off.
    • Note: if your buckle has actually broken or snapped, use a "seam ripper" tool, or small pair of scissors to carefully cut the threads holding the seam together. Then remove the defective buckle and obtain a replacement.
  2. How to repair a buckle (ski braces), Clean the area: adım 2, 3 resimden 1. How to repair a buckle (ski braces), Clean the area: adım 2, 3 resimden 2. How to repair a buckle (ski braces), Clean the area: adım 2, 3 resimden 3.
    • Cut away the damages thread to clean the area, ready for repair.
  3. How to repair a buckle (ski braces), Reinsert the buckle: adım 3, 3 resimden 1. How to repair a buckle (ski braces), Reinsert the buckle: adım 3, 3 resimden 2. How to repair a buckle (ski braces), Reinsert the buckle: adım 3, 3 resimden 3.
    • Insert the buckle in the fabric loop.
    • Check that the position is correct, and that the other half of the buckle will clip on correctly.
    • Note: It is easy to sew the clip in back-to-front - so one extra check before stitching is worthwhile!
  4. How to repair a buckle (ski braces), Stitching: adım 4, 3 resimden 1. How to repair a buckle (ski braces), Stitching: adım 4, 3 resimden 2. How to repair a buckle (ski braces), Stitching: adım 4, 3 resimden 3.
    • Fix the buckle in place, by sewing along the seam with the sewing machine.
    • Place the assembly under the sewing machine, depress the foot, and made a straight stitch from one end to the other.
    • Repeat the process 1-2 times for extra durability; and add a lock stitch on both ends.
  5. How to repair a buckle (ski braces), Finished and ready!: adım 5, 1 resimden 1.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
9.298 İtibar
64 adet Kılavuz yazıldı
Ekip
INTERSPORT INTERSPORT üyesi
Community
24 Üyeler
164 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 172
