Ana içeriğe geç
How to repair a buckle (ski braces)
Neye ihtiyacın var
  1. How to repair a buckle (ski braces), Identify the defect: adım 1, 3 resimden 1. How to repair a buckle (ski braces), Identify the defect: adım 1, 3 resimden 2. How to repair a buckle (ski braces), Identify the defect: adım 1, 3 resimden 3.
    • The buckle stitching is broken, and the buckle has fallen off.
    • Note: if your buckle has actually broken or snapped, use a "seam ripper" tool, or small pair of scissors to carefully cut the threads holding the seam together. Then remove the defective buckle and obtain a replacement.
  2. How to repair a buckle (ski braces), Clean the area: adım 2, 3 resimden 1. How to repair a buckle (ski braces), Clean the area: adım 2, 3 resimden 2. How to repair a buckle (ski braces), Clean the area: adım 2, 3 resimden 3.
    • Cut away the damages thread to clean the area, ready for repair.
  3. How to repair a buckle (ski braces), Reinsert the buckle: adım 3, 3 resimden 1. How to repair a buckle (ski braces), Reinsert the buckle: adım 3, 3 resimden 2. How to repair a buckle (ski braces), Reinsert the buckle: adım 3, 3 resimden 3.
    • Insert the buckle in the fabric loop.
    • Check that the position is correct, and that the other half of the buckle will clip on correctly.
    • Note: It is easy to sew the clip in back-to-front - so one extra check before stitching is worthwhile!
  4. How to repair a buckle (ski braces), Stitching: adım 4, 3 resimden 1. How to repair a buckle (ski braces), Stitching: adım 4, 3 resimden 2. How to repair a buckle (ski braces), Stitching: adım 4, 3 resimden 3.
    • Fix the buckle in place, by sewing along the seam with the sewing machine.
    • Place the assembly under the sewing machine, depress the foot, and made a straight stitch from one end to the other.
    • Repeat the process 1-2 times for extra durability; and add a lock stitch on both ends.
  5. How to repair a buckle (ski braces), Finished and ready!: adım 5, 1 resimden 1.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
9.298 İtibar
62 adet Kılavuz yazıldı
Ekip
INTERSPORT INTERSPORT üyesi
Community
22 Üyeler
161 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 144
